JPEG image dimensions
magnussandstrom
Post by magnussandstrom »
Hi everyone,
I'm facing an issue while trying to retrieve image dimensions from a JPEG file in Switch. I need to calculate the dimensions by dividing the pixel count by the resolution and then display the result in a Checkpoint field.
For TIFF images, the following expression works:
[Switch.Calculation:Expression="round([Switch.Calculation:Expression="[Image.ImageWidth]/([Image.XResolution])"]*25.4)"]
However, this doesn't seem to work for JPEG images.
Does anyone know how to extract this information correctly for JPEG files in Switch? Any suggestions would be greatly appreciated!
Thanks!
jan_suhr
Re: JPEG image dimensions
Post by jan_suhr »
Seems that it only works with TIFF,
https://www.enfocus.com/manuals/UserGui ... group.html
But try to extract the XMP data with the XMP Pickup tool, it might find what you need
Jan Suhr
Color Consult AB
Sweden
Check out my apps
JimmyHartington
Post by JimmyHartington »
EDIT: Forget you needed the resolution as well. So this is NOT available in Stats.
But I let the answer stand if anybody needs the pixel-dimension of a jpg.
Could you instead use the info from Stats?
JimmyHartington
The resolution is possible to extract with Exiftool if you would not mind introducing another program.
Updated with -b for trimming result from ExifTool.
magnussandstrom
Yes, I installed exiftool the other day and can do it that way. I hoped there was a more straight forward solution.
JimmyHartington
OK. Can I ask what the calculated value is used for?
Jimmy wrote that [Stats.PixelXDimension] does show the correct value for JPEG, but it also shows the correct value for TIFF files. Ergo, replace [Image.ImageWidth] by [Stats.PixelXDimension] in the calculation and it will work for both image types.
magnussandstrom
freddyp wrote: Mon Mar 17, 2025 9:27 am Jimmy wrote that [Stats.PixelXDimension] does show the correct value for JPEG, but it also shows the correct value for TIFF files. Ergo, replace [Image.ImageWidth] by [Stats.PixelXDimension] in the calculation and it will work for both image types.
Yes, but where can I find the resolution for a JPEG in Switch?
magnussandstrom
JimmyHartington wrote: Mon Mar 17, 2025 9:17 am OK. Can I ask what the calculated value is used for?
I have a flow for wallpaper-creating where I like to present the initial dimensions in a checkpoint before the next step, like this:
Skärmavbild 2025-03-17 kl. 15.06.44.png (174.51 KiB) Viewed 94391 times
In [Image.XResolution] and [Image.YResolution]. If not, share the image so I can investigate.
jan_suhr
Post by jan_suhr »
The XMP data for a JPEG looks like this in Photoshop
<tiff:XResolution>72/1</tiff:XResolution>
<tiff:YResolution>72/1</tiff:YResolution>
And in Switch it looks the same with [Image.XResolution] = 72/1 for a JPEG image.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
magnussandstrom
freddyp wrote: Mon Mar 17, 2025 3:54 pm
It's seems like the JPEG images I trying with doesn't contain the meta data that Switch are looking for. Some JPGs works fine and other do not. I'll send you a "faulty" JPG Freddy.
bens
Post by bens »
Yeah physical resolution is an optional tag in JPEG (and in many other image formats), so indeed not all files have it.
