Using 2 different Switches for illustrator
Terkelsen
Re: Using 2 different Switches for illustrator
Post by Terkelsen »
If you simply drop say 25 files into the IN folder, how do you decide which ones are number 10 and 20?
tvahey
Post by tvahey »
You can use some conditional logic based on a counter or a number in the file name. Here's an example using a counter in private data...
Flow attached
Does this do what you want?
May I ask why you are sorting the jobs this way?
*edited flow to send "all other" jobs to 1-9 outgoing connector
Sort Jobs 1-9 2.sflow.zip
Sort Jobs based on Counter
(15.64 KiB) Downloaded 821 times
Screenshot 2025-03-21 at 7.39.05 AM.png (33.1 KiB) Viewed 30085 times
