JPEG image dimensions
- magnussandstrom
Hi everyone,
I'm facing an issue while trying to retrieve image dimensions from a JPEG file in Switch. I need to calculate the dimensions by dividing the pixel count by the resolution and then display the result in a Checkpoint field.
For TIFF images, the following expression works:
[Switch.Calculation:Expression="round([Switch.Calculation:Expression="[Image.ImageWidth]/([Image.XResolution])"]*25.4)"]
However, this doesn't seem to work for JPEG images.
Does anyone know how to extract this information correctly for JPEG files in Switch? Any suggestions would be greatly appreciated!
Thanks!
Thanks!
Re: JPEG image dimensions
Seems that it only works with TIFF,
https://www.enfocus.com/manuals/UserGui ... group.html
But try to extract the XMP data with the XMP Pickup tool, it might find what you need
- JimmyHartington
EDIT: Forget you needed the resolution as well. So this is NOT available in Stats.
But I let the answer stand if anybody needs the pixel-dimension of a jpg.
Could you instead use the info from Stats?
- JimmyHartington
The resolution is possible to extract with Exiftool if you would not mind introducing another program.
Updated with -b for trimming result from ExifTool.
- magnussandstrom
Yes, I installed exiftool the other day and can do it that way. I hoped there was a more straight forward solution.
- JimmyHartington
OK. Can I ask what the calculated value is used for?
Jimmy wrote that [Stats.PixelXDimension] does show the correct value for JPEG, but it also shows the correct value for TIFF files. Ergo, replace [Image.ImageWidth] by [Stats.PixelXDimension] in the calculation and it will work for both image types.
- magnussandstrom
Yes, but where can I find the resolution for a JPEG in Switch?
- magnussandstrom
I have a flow for wallpaper-creating where I like to present the initial dimensions in a checkpoint before the next step, like this:JimmyHartington wrote: ↑Mon Mar 17, 2025 9:17 am OK. Can I ask what the calculated value is used for?
In [Image.XResolution] and [Image.YResolution]. If not, share the image so I can investigate.Yes, but where can I find the resolution for a JPEG in Switch?
The XMP data for a JPEG looks like this in Photoshop
<tiff:XResolution>72/1</tiff:XResolution>
<tiff:YResolution>72/1</tiff:YResolution>
And in Switch it looks the same with [Image.XResolution] = 72/1 for a JPEG image.
- magnussandstrom
It's seems like the JPEG images I trying with doesn't contain the meta data that Switch are looking for. Some JPGs works fine and other do not. I'll send you a "faulty" JPG Freddy.
Yeah physical resolution is an optional tag in JPEG (and in many other image formats), so indeed not all files have it.
