HTTP Request Error
ezninnovation
HTTP Request Error
Post by ezninnovation »
I started getting this error. I have stripped all variable data out of the URL for testing and just making a static call that works in Postman but is failing with this error in Switch.
Cannot read properties of undefined (reading 'status') TypeError: Cannot read properties of undefined (reading 'status') at a0_0x40c41b.processCurrentJob
Rest of the error here:
(C:\Users\switch\AppData\Roaming\Enfocus\SwitchProcessorService\cache\7f1ff3b80ea955a15d57c6797ae61f06e7c430c8ab16327ec2ca2029c1515c7e\1746771349\main.js:1:27175) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async a0_0x40c41b.perform (C:\Users\switch\AppData\Roaming\Enfocus\SwitchProcessorService\cache\7f1ff3b80ea955a15d57c6797ae61f06e7c430c8ab16327ec2ca2029c1515c7e\1746771349\main.js:1:21278) at async jobArrived (C:\Users\switch\AppData\Roaming\Enfocus\SwitchProcessorService\cache\7f1ff3b80ea955a15d57c6797ae61f06e7c430c8ab16327ec2ca2029c1515c7e\1746771349\main.js:1:20995) at async _0x200e34 (C:\Program Files\Enfocus\Enfocus Switch\ScriptExecutor\nodemodules\node_modules\switch-scripting\index.js:1468:28) at async C:\Users\switch\AppData\Roaming\Enfocus\SwitchProcessorService\cache\7f1ff3b80ea955a15d57c6797ae61f06e7c430c8ab16327ec2ca2029c1515c7e\1746771349\main.js:1:71638
Malcolm Mackenzie
Re: HTTP Request Error
Post by Malcolm Mackenzie »
a bug in 20.4 of the app
ezninnovation
Any suggestions or workarounds? Do I need to go back to 20.3?
ezninnovation
Malcolm Mackenzie wrote: Tue Aug 12, 2025 3:41 pm a bug in 20.4 of the app
Malcolm Mackenzie
Yes reverting should be good.
ezninnovation
Seems like a double edge sword. With 20.3 I have basic authentication issues but with 20.4 I have the other error. Hopefully this gets addressed soon.
rocky07
Post by rocky07 »
This error usually means the HTTP Request app in Enfocus Switch isn’t receiving a proper response object from the server, so when it tries to read the `status` property, it fails because it’s undefined. Even though the URL works fine in Postman, Switch may be blocking or mishandling the response due to missing headers, authentication, or an invalid response format. Double-check that your request method, headers, and SSL settings match your Postman setup. Also, wrap your response handling in a try/catch block or add a response check before accessing `response.status` to avoid the crash.
