Does anybody have an action to great a dubble sided kiosk flag. (little flag where to top half is in an angle off 45 degrees, where the stick goes)
Problem is that the top need to be mirrored and turned in a angle of 45 degrees so whenb the tunnel for the stick is made the image on both sides is correct.
We doing it now by hand in indesign but would like to have an action for that.
kiosk flag
- JimmyHartington
Re: kiosk flag
Can you share some examples of input and desired output?
Preferably as pdfs.
Preferably as pdfs.
Re: kiosk flag
quote=JimmyHartington post_id=19630 time=1765187735 user_id=193]
Preferably as pdfs.
[/quote]
Preferably as pdfs.
[/quote]
- JimmyHartington
Re: kiosk flag
And is this input or output?
An example of both would make it easier to see what should be achieved.
Re: kiosk flag
Yes this is the output. Front and back together. We will first print this side and then de other side with the same image.
(after cutting the shape we have 2 flags)
Here is a file with 2 pages one front one backside.
Problem is de top side in 45 degrees that we need to mirror
- Schuine_vlag_Def_02_L.pdf.zip
- (68.07 KiB) Downloaded 268 times
- JimmyHartington
Re: kiosk flag
I am not at a company where we make beach flags, so I need a pdf of how you want the 2-sided pdf to look after the action list has run.
So the work you do in InDesign manually today.
