Long Processing Times After Module Updates
DamienB
Post by DamienB »
Every time I update my modules, my workflows take more than two hours to run again (I have over 100 of them).
This makes me reluctant to perform updates… especially when those updates introduce issues and break the workflows. If I need to roll back, everything gets blocked again for a long time.
Do module updates take that long for you as well? What’s your strategy?
My Switch is running on a Windows VM.
Thank you for your feedback.
Damien
WDBonline
Re: Long Processing Times After Module Updates
Post by WDBonline »
I assume that the cleanup for processed tickets is set for keep too long.
We also had this issue (like restarting took too long), see screenshot.
FYI: Cleaning these tickets are only for processed files, so logs are still available after 48h.
Scherm­afbeelding 2025-12-03 om 12.09.23.jpg (105.03 KiB) Viewed 15377 times
DamienB
Post by DamienB »
Thank you,
I'm testing it quickly.
tdeschampsBluewest
Post by tdeschampsBluewest »
Hi, While it’s still true overall, we’ve noticed a clear improvement in update times with Switch 25.11.
Updating PitStop on my test machine (with 400+ flows) used to take ages, but now it only takes about ~5 minutes, just enough time to take a well-deserved break:)
magnussandstrom
Post by magnussandstrom »
tdeschampsBluewest wrote: Fri Dec 05, 2025 7:11 pm Hi, While it’s still true overall, we’ve noticed a clear improvement in update times with Switch 25.11.
This sound VERY promising!
DamienB
Post by DamienB »
Yes, it looks promising.
I'm still waiting a little before switching to Switch 2025... I had too many bad surprises during the updates.
Thank you for this feedback
magnussandstrom
I updated from 2024 fall to 25.11 3 days ago, and after that I also updated all apps and Pitstop Server. The upgrade process was much faster especially the "Update flows process". We have had no issues after the upgrade.
