Is there anyway to use the feature of Griffin "Fit to layout" on Griffin Auto ?
Best regards.
Griffin Auto - Fit to layout
- magnussandstrom
Re: Griffin Auto - Fit to layout
If you by "Fit to layout" refering to be able to crop the imposed file to the utilized substrate area the answer is no. When Enfocus presented the new Griffin Auto app in the Webinar this was brought up as an feature request and Freddy indicated that this might be avaliable in a future release of the Griffin Switch app. I cannot find a feature request on the official Switch feature request portal though.
- magnussandstrom
I've now supplied a feature request "Griffin Auto - Crop to layout" in the portal: https://my2.enfocus.com/en/switch/featurerequests
I think the issue is that this isn't supported in the API. The desktop app must work out the size of the imposition and be able to adjust it.
To do this currently in Switch if the media data allowed you could nest the job once and then route it back using the substrate dimensions in the meta data if possible.
- magnussandstrom
Do you think it will be supported by the API in the future?jasonx wrote: ↑Tue Mar 10, 2026 7:32 am I think the issue is that this isn't supported in the API. The desktop app must work out the size of the imposition and be able to adjust it.
- magnussandstrom
Good news! In the new release of Griffin “fit layouts to content” is introduced in the API. Let's hope we'll get an update to the Griffin App that also supports this new feature.
