Version 26.03 issues
Benepress
Post by Benepress »
Is anyone else having the same issues since the latest update to 26.03? I've noticed when using the Inspector and selecting any object with a fill and/or stroke, the colour does not register. It shows X in both fill and stroke boxes. The colour does however show below in the colour sliders. When I try to convert a selected object from RGB to CMYK, I get an error message "Invalid ICC Profile". So basically I can't use my Pitstop for colour conversions!
loicaigon
Re: Version 26.03 issues
Post by loicaigon »
Hi all,
This has been identified as a result of CMM settings which was not changed since Apple introduced Slash characters instead of Semi-Colons for file paths.
Fortunately enough, an easy fix is to refresh your CMM settings by quickly change them and back. Afterwards, everything is expected to work as normal.
This really only affects macOS users who never changed CMM settings.
Apologies for the inconvenience though.
Benepress
Post by Benepress »
Thanks Loic, I was able to fix the problem using Botus.
yosimo
Post by yosimo »
Hi all,
I noticed that the Action Lists window can now be displayed in multiple columns, and the Action Lists can be sorted by the column header, such as by date, name or author.
What I don’t like about this is that the entries in the “Recent” section are now also sorted this way. It was always very helpful that the most recently used action list was always at the very top, and all the others moved down one position.
Is it possible to restore this behavior?
yosimo
PitStop User
loicaigon
Post by loicaigon »
Hi Yosimo,
The behavior won't be restored. However, I believe you should get this result by sorting by the last modified date column?
yosimo
Post by yosimo »
Hi Loïc,
loicaigon wrote: Thu Apr 09, 2026 10:09 am ... should get this result by sorting by the last modified date column?...
No, the modification date is the date the action list was created. However, this does not change when the action list is executed.
yosimo
PitStop User
PPNINJA
Post by PPNINJA »
We've just updated and checking out new features...Loving the distribute along path.
My only gripe at the moment is with the new column view...is there a way to custom sort the lists?
Currently the default is sorted by name alphabetically..is there way to turn off so i can customise the list?
Egon
Post by Egon »
Thanks for the tip Loïc!
By resetting the CMM (Color Management setting) back to the Enfocus Default Presets, all previews started working again!
loicaigon wrote: Tue Mar 31, 2026 9:08 am Hi all,
Enfocus Pitstop Pro | Enfocus Pitstop Server | Enfocus Switch | ArtiosCad | Workflow Designer
Linkedin | GraphicWorld bv.
Egon
Post by Egon »
I do have another issue!
It seems like I can no longer reorganize my Actions in the Action List. Is that correct? :roll:
Or is there a sorting option that I'm missing?
I'm obviously referring to my "Favorites"! I used to be able to drag them around a bit so that I had the most frequently used Actions at the top.
