Pitstop Library error code 8008
lucero21414
Post by lucero21414 »
Hello! Does anyone know what this error means?
349: Error while saving pdf report (PitStop Library error code 8008): PDF Access wrong object type error.
I'm seeing it in the Switch error messages for various Pitstop elements where Preflight reports are saved, but I don't know what exactly is causing it.
Thank you!
bens
Re: Pitstop Library error code 8008
Post by bens »
That error generally means the input file is corrupt. For example if a page box is not an array of 4 numbers, that's a wrong object type error.
Sometimes resaving the file in Acrobat fixes the problem.
