Hi All@Community
I used to setup in the past some workflows from a competitor product from DALiM.
For sorting and creating files, we were using functionalities based on RegEx :
Pattern = (.+)_(.+)_(.+)_(.+)_(.*[^0-9])?0*([0-9]+)(.*)
Path LowRes = /Volumes/DATA/Secure/SecuriZ/[string range #1 0 7]/[string range #2 0 5]/[string range #3 0 10]_[string range #4 0 2]/Placements
File EPS = [string range #3 0 10]_[string range #4 0 2]_[format %03d #6].eps
The STRING_RANGE was used to pickup some characters inside each part of the incoming file.
Example : [string range #3 0 10]_[string range #4 0 2]_[format %03d #6].eps
was creating a file by picking the first eleven characters of the pattern #3, 3 characters of the pattern #4, format %03d #6 formatting the page number (001, 002, etc... 999).
How do you proceed with SWITCH to have a such behaviour ?
The main goal is :
- Let say input file is DOCUMENT_NAME_PRODUCTCODE.pdf
- Create hierarchy by picking any of the characters like DOCUMENT or NAME or PRODUCTCODE, by eventually cropping them to reduce the numbers of characters,
- Final PDF files will be DOCUMENT_NAME_PRODUCTCODE_001.pdf, DOCUMENT_NAME_PRODUCTCODE_002.pdf, .../... DOCUMENT_NAME_PRODUCTCODE_999.pdf
I know how to used "Split files" from SWITCH.
Many thanks for ideas and comments
Bye
