Yes, I've been working from InDesign on the Switch ServerThe SmartStream plugin is installed on the Switch Server?
Yes, other SmartStream flows works correctlyIs the license set up properly?
OK, will give it a trySave the csv as a txt and try it again?
Done that as I've tried a couple of different locations for the template folder.I would also triple-check the template path in the configurator settings.
YesDo you have the Switch/Smartstream on the same computer as then you make the the test that all is OK?
No extended characters in the file path. Full folder path is: Enfocus Switch Developer/Macintosh HD/Users/switchdeveloper/Documents/VDP_TemplatesThe total search-way on the computer, no extended characters?
The computer is set to english as preferred language and I use english terminology for everything in case I need Enfocus technicians to connect to the computer for troubleshooting...
