And it worked!lombert wrote:Thanks. Now it change the parameter.
I will try this at the press on friday (Swedan has an holiday tomorrow so no work..)
SmartStream Banner JDF
Re: SmartStream Banner JDF
Between jobs!
Glad to hear. Let me me know if you have any other issues.
Just to confirm, both issues are solved at this side with v9 of the DFE configurator.
r.zegwaard
@Chad: Is there any chance by now that it is possible to set the bannersheet in the Switch Configurator? (or in the (near) feature...
You can set Banners and Dividers in the JDF configurator:
Is there something other than what is currently available that you need to do?
Also note that Banner sheets are only supported on series 3 and 4 presses (7x00, 10,000, 12,000 etc.)
