I've a perfect working workflow with the HP configurator. I've duplicated the flow to use it for an other purpose. Now each file is going into error. message is "14/06/18 18:57,Error,HP Digital Front End JDF Control,CPC-W2P,HP Digital Front End JDF Control,0QCWT,CPC 00005_D3-MYP.pdf,Dynamic property 'copies' has invalid value ''
Why does it work in one flow and not in the other?
Fist
Re: Dynamic property 'copies' has invalid value
This normally happens when you're using single line text with variable or script expression that isn't resolving to a positive integer value. What do you have set for that property?
