I have the latest version of PitStop Server installed however for some reason, I receive the following error multiple times per day: "PitStop Server Watchdog has restarted PitStop Server Processor because of an unexpected problem."
I've checked the event viewer but I'm not seeing any events that correlate to the time and/or issue.
I've done quite a bit of searching and can't pinpoint anything in particular.  Aside from calling support, has anyone else experienced this issue before?  We're currently running everything with a local user on the computer in order to take advantage of some plugins in Switch.  I'm not sure if this is causing the issue but I figured it was worth mentioning.
						PitStop Server Watchdog has restarted...
				kwoodVisions
				kwoodVisions
Re: PitStop Server Watchdog has restarted...
Now it's stopped working and this is the information in the Event Viewer:
Faulting application name: PitStopServerWatchdog.exe, version: 18.0.1.0, time stamp: 0x5b05640f
Faulting module name: ntdll.dll, version: 6.3.9600.18969, time stamp: 0x5aa29ff0
Exception code: 0xc0000374
Fault offset: 0x00000000000f1cd0
Faulting process id: 0x1744
Faulting application start time: 0x01d45f4bbaa450e2
Faulting application path: C:\Program Files\Enfocus\Enfocus PitStop Server 18\PitStopServerWatchdog.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: f89d5f25-cb3e-11e8-80df-00155dc81001
Faulting package full name:
Faulting package-relative application ID:
