Report Page Boxes in Inches?
prepress
Post by prepress »
My reports used to be in inches.
Now they are in points.
Help?
Thanks.
LasseThid
Re: Report Page Boxes in Inches?
Post by LasseThid »
If this is in Switch, then check the settings for your PitStop Server configurator.
At the bottom there's a setting for which unit to use in the report.
prepress
Post by prepress »
Nope. Pitstop Pro.
LasseThid
Post by LasseThid »
OK, then check your PitStop Pro settings.
If I run a preflight and then create a preflight report I get mm as the unit.
Skärmavbild 2019-01-31 kl. 21.25.38.png (96.75 KiB) Viewed 15138 times
prepress
Post by prepress »
Aaaah. Thank you.
There is a seperate setting for Pitstop PREFERENCES.
Did not realize that THIS report preference comes from the plugin preferences.
Thank you.
LasseThid
Post by LasseThid »
You're quite welcome.
Sometimes it's hard to see the woods because of all of the trees... :lol:
PitStop pro related things may have a preferences setting under the PitStop Pro preferences.
Even the offset when you copy/paste has a setting in here, which might be quite useful...
