Hi
Is anybody else having trouble with using Acrobat Distiller in Switch flows.
This was working fine until recently (may be related to an Acrobat update) but now PS files error immediately.
The Switch messages says to check the log file but none is created. I thought it might be a security issue as Distiller stand alone kept asking for permission to distill any file. However I have now changed this in preferences but still no luck. By the way watched folders seem to work fine also.
Running Switch 2018 on windows.
Cheers James
Distiller & Switch
Re: Distiller & Switch
Hi Neosa
Yes I think your probably right.
I'll look into the solutions.
Thanks for the info.
James
James
Is this issue fixed in Switch 2019?
May I ask why you use Distiller?
It is a very very outdated way of doing things.
Hi Jan
We only use distiller when cleaning up problem PDF's supplied by clients.
The Flow is designed to save PDF to postscript then re-distill and is not part of our standard workflow.
James
James
Ok I understand now
Hi Just to confirm this is not fixed by installing 2019 versions.
I have used the generic application/hot folder work around for now.
