QR Code create
abonsey
QR Code create
Post by abonsey »
Hi All,
Looking to create a QR code from a csv field.
Has anybody already done a script or got any advice on how to create the EPS so that I can place it in the PDF?
TIA
sander
Re: QR Code create
Post by sander »
I use SmartStream Designer together with Barcode Studio for this;
Input is a CSV, so guess that's what you need :)
So, do you have SmartStream Designer? :roll:
Re: QR Code create
You can use a command line tool named "qrencode" that you run in the Execute Command element. You need a proper formated textfile for qrencode to process and it will save an .eps as a QR Code.
You will find it here: https://fukuchi.org/works/qrencode/
Jan
