RegExp _ SOLVED
victor Lukenga
RegExp _ SOLVED
Post by victor Lukenga »
Hi !
I Experiment with RegExp i want to Extract a Hyphen without go in scripting
(0, 0, 314.81677, 114.81682) mm
I want to Extract two element
In the "search" field I typed ([0-9]+.[0-9]) and I get 314.8
but how to extract 114.8 ?
Can you help me ?
Last edited by victor Lukenga on Thu Mar 24, 2016 9:51 am, edited 1 time in total.
Re: RegExp
Hi Victor,
An option is to use after/before modifiers to isolate the value:
HTH
Loic
http://www.ozalto.com
victor Lukenga
Re: RegExp
Thank you Loic
I don't know why I didn't think about that ! I feel silly :)
Thank You so much
Re: RegExp _ SOLVED
Infact the RegEx you wrote will find both the third and fourth segment of your string.
This RegEx will only find the last segment:
(?!\s)([0-9]+\.[0-9]+)(?=\))
It will exclude the space before and the ) at the end in the result but look for them in the search.
I use a great tool to write the RegEx and it gives you instant feedback on what you do.
http://www.mactechnologies.com/index.ph ... ds#regexrx
Jan
victor Lukenga
Re: RegExp _ SOLVED
your software is pretty cool !
I like to use this site http://regexr.com/ it's very helpful to build and test your regex
