Saxon to save multiple node XML
abonsey
Post by abonsey »
I'm using Saxon to save multiple node XML to single XML.
This works fine when the XML is supplied in the following format:
<Items>
<Item>
<LineNumber>PM5853</LineNumber>
In the XSLT the instruction for the file name looks like this and this file creates fine:
<xsl:result-document method="xml" href="{LineNumber}.xml">
The problem I have is that some XML is being supplied as:
<Items>
<Item LineNumber="PM5853" Rush="No" type="New" approved="NA" WaitingScheduler="No">
This causes the XSLT to fail.
My question is how to I correctly call for {LineNumber} for this type of XML
Thanks for any help.
Re: Saxon to save multiple node XML
Try this
 <xsl:result-document method="xml" href="{item/@LineNumber}.xml">
Jan
