Insert common page to a multipage document
sprints
Post by sprints »
Trying to locate how to insert a common back to a file containing 1000 business cards. Any assistance would be greatly appreciated.
Thank you for your assistance!
Terkelsen
Re: Insert common page to a multipage document
Post by Terkelsen »
I think you will need to tell more specific about what you are trying to achieve. What kind of file are we talking about? Is this one file containing 1000 pages or is it an imposed sheet, where you want to step and repeat the same back on each businesscard?
sprints
Post by sprints »
It is a pdf documents that has not been imposed. Page 1 is the common back to each of the other pages.
strido
Post by strido »
If you create a new action list, and search for "Add Pages" - there's a setting in there to add from a file. So Open up your business card file, and create it.
Then you'd point toward whatever file you want to use as the backer.
Change your page range to 1-1000
Method: Insert Indicated page 1 time(s)
In the location, check After Pages and put in 1-1000.
That should do it.
sprints
Post by sprints »
In the interest of time I had to print one side of common, then the other sequential cards. I'll give this a try for next time, thanks :D
