add pagelabels to pdf
rschipper
Post by rschipper »
Is there any way in switch to extract the filename of a pdf, and add the filename as page label in the pdf?
For example: job_123456.pdf and set the page label of every page to 123456.
regards,
Robert
Erazor
Re: add pagelabels to pdf
Post by Erazor »
I have the same question, anyone have an answer?
magnussandstrom
Post by magnussandstrom »
If you got Pitstop Server it's easy to do it. See attached flow.
page_label.zip
(17.34 KiB) Downloaded 1591 times
Erazor
Post by Erazor »
Thank you very much Magnus, I will give it a go and let you know.
