Connect You upgrade 3
plantage
Post by plantage »
I was wondering if Connect You Upgrade 3 is compatible with the new MacOS Sierra...
Anyone tested it?
Marc
Re: Connect You upgrade 3
Hi Marc,
It is impossible to officially support any OS before it is released. Apple does provide test builds before the release, but there are always changes in the final release, which makes it impossible to be 100% sure beforehand. And of course if any changes are needed for compatibility, this happens in a new release, so any software released before Sept. 20 cannot officially support Sierra.
So the official response is: Sierra is not listed on https://www.enfocus.com/en/support/syst ... quirements so it is not supported. It will not be supported until the next Connect YOU release.
With that in mind I strongly suggest that, if you want to try it, you don't do it on your production machine but on a separate one.
Ben
plantage
Post by plantage »
I understand, thanks Ben.
Michael Reiher
Post by Michael Reiher »
We have done testing with Sierra and everything passed our tests. It should be fine.
Michael
plantage
Post by plantage »
Good to hear that! Thanks!
