Help with RegEx
Posted: Wed Oct 26, 2016 3:47 pm
by Terkelsen
I have found the following Regular Expression very useful to look for a URL in a long text string:
(ftp:\/\/|www\.|https?:\/\/){1}[a-zA-Z0-9u00a1-\uffff0-]{2,}\.[a-zA-Z0-9u00a1-\uffff0-]{2,}(\S*)
Used on the following text string:
<td bgcolor="white" style="padding:5px !important;” class=“”><a href="https://www.jotformeu.com/uploads/Terke ... /DEMO.xlsx" class="">DEMO.xlsx</a></td>
... it will return this:
It works very well with variables in Switch. The only problem is the dobbelt quote at the end of the string, so I changed the RegEx to this:
(ftp:\/\/|www\.|https?:\/\/){1}[a-zA-Z0-9u00a1-\uffff0-]{2,}\.[a-zA-Z0-9u00a1-\uffff0-]{2,}(\S[^"]*)
... adding [^"] to Group 2
Checking this in different online RegEx evaluators, it works fine, but if I use it in Switch, it breaks everything and only returns this: *)"].
Could anybody tell me how to change the RegEx to exclude the dobbelt quote at the end of the URL, AND have it work in Switch?
Re: Help with RegEx
Posted: Wed Oct 26, 2016 4:26 pm
by TheCaptain
I've found Switch likes having this expression
{2,}
fully quantified i.e
{2,6}
... and often works best without the comma if that's possible.
Also, where I've had a longer expression, sometimes enclosing the entire thing once more in '(' and ')' can help.
from
(this{2})\b
to this
((this{2})\b)
sort of thing.
Re: Help with RegEx
Posted: Thu Oct 27, 2016 9:11 am
by Terkelsen
Excuse my ignorance, but I don't think I understand how this could solve the problem?
I need a way to exclude the double quote (") from the result that is returned. In a javascript RegEx this would work
but it can't be used inside Switch
Re: Help with RegEx
Posted: Wed Nov 02, 2016 2:30 pm
by loicaigon
Hi Terkelsen
This regexp seems to do it:
(http|ftp|https)://([\w_-]+(?:(?:\.[\w_-]+)+))([\w.,@?^=%&:/~+#-]*[\w@?^=%&/~+#-])?
HTH
www.ozalto.com
Re: Help with RegEx
Posted: Thu Nov 03, 2016 11:40 am
by Terkelsen
Hi Loic,
That was a different approach but it solves the problem ;)
Thanks a lot.
Re: Help with RegEx
Posted: Thu Nov 03, 2016 12:12 pm
by loicaigon
You're welcome !
