problem inject lite
Posted: Thu Dec 22, 2016 1:41 pm
				I am having a small problem with inject lite function in switch 13.1.
If I choose at Target --> jobpath, a fixed path/file the function works fine. If the file is present it will go trough the "succes line" and if the file isn't present the job go trough the "error line".
When I change a part of the fixed path by a job variabele the fuction doesn't work anymore. If the file is present it will go trough the "succes line" but when the target file is not present it goes to the problem jobs.
