Global RGB Curve Adjustment
Paulasaurus
Post by Paulasaurus »
I have some RGB image files that i'm trying to make global curve adjustments on and am hoping someone might be able to help. While using the Enfocus Inspector I am able to make adjustments to single image RGB curves without issue. It looks as if the Inspector is able to automatically load the correct color channels in order to make the curve adjustments. Now when I bring up the Global Change action pallet there is not an option for RGB channels. I only have the choice between CMYK and Other. Is there a way to make global curve adjustments to a file containing RGB images? I do not want to convert my images to CMYK.
Thanks in advance for the help!
Re: Global RGB Curve Adjustment
You can create an Action List with:
Select images
Apply RGB curve
Paulasaurus
There it is! I completely over looked it in the action lists.
Greatly appreciate the help!
smithclarkson01
Post by smithclarkson01 »
creating an action list is very easy , do it via
Select images
