Network to Network Copying Issue?
MarkStrecker
Post by MarkStrecker »
I am new to Switch. I set up a flow that copies files from one network server to another. The sending network server is at my print plant, and the receiving one is a different print plant. Right now files only copy to the receiving server one at a time. If there were an FTP server or mail, Switch is mre than capable of copying several files at once. Is there a way to do this with a simple network server to network server setup?
Screenshot 1.jpg (81.57 KiB) Viewed 5188 times
enfocus
Re: Network to Network Copying Issue?
Post by enfocus »
This article might explain the behavior you see:
https://www.enfocus.com/en/support/know ... 0018XxsAAE
If the behavior you see can't be explained by the article, then you can have it investigated by Enfocus if you have a valid Switch maintenance contract. You can contact Enfocus Support via the support portal: https://www.enfocus.com/en/supportportal
If you don't have a valid Switch maintenance contract, then it can be investigated by your reseller.
