Clean up filenames from XML
cwswitch
Post by cwswitch »
An XML is sent to Switch, and that is the first point that I have any control over what is sent. There's no ability (or interest) upstream to help me here.
As the information is in the XML, and XML can't have certain characters in it, then I have trouble injecting jobs.
Example filename in the XML
foo/bar/baz&bazz.pdf
Related file on the file server that I need to inject
I'm looking to pull the XML path into private data, clean it up, then call Inject using the clean name. It is not just &, it is any symbol that can't be rendered in XML in plain text.
I've gone several ways and fallen every time. I'm sure others must have come across this issue but I've not found anything on line.
Any help greatly appreciated.
Re: Clean up filenames from XML
The XML pickup tool will handle the & and translate it to the proper baz&bazz.pdf filename. As long as the XML is valid it will work in Switch. The inject tool will pickup your file.
Screen Shot 2017-09-01 at 08.36.58.png (43.92 KiB) Viewed 34744 times
Jan
cstevens
Post by cstevens »
You could open it as a standard file and do a simple string.replace(/&/g, '&'), then save the file and send it to an XML pickup for further processing. I did something similar for corrupted csv files.
Shawn_Anderson
Post by Shawn_Anderson »
I had to use Switch to help pass XML from one workflow to another and ran into the same issue. One way of doing this is to use Execute Command with sed. This should comment out any ampersands in the incoming XML, but you can edit the sed command for any other chars you want to replace.
Command: path/to/bash/script/cleanupXML.sh
Arguments: "%1" "%2"
Output: File at Path
content of cleanupXML.sh script
#!/bin/bash
sed "s/\&/\&/g" "${1}" >> "${2}"
taylorgodiva28
Post by taylorgodiva28 »
you can use ELEMENTS statements to replace <row> clauses with each row. Previously, we didn't specify the ELEMENTS directive, so it returned the default value.
Geometry Dash Scratch
