sendToSingle() doesn't send until script finishes
Posted: Fri Sep 15, 2017 1:34 am
I have a script the reads a text file of file paths and processes them in a loop. There could be a thousand or more items in the text file. It appears that the sendToSingle() command doesn't "release" the jobs until the script finishes. This is an issue because there could be hundreds of gigabytes of files that are suddenly copied to the Switch server for processing, then the system drive fills up and crashes. Is there a way to have the script send the jobs along WHILE the script is running? I know I could make a single text file for each file to process, but like I said before, there could be a thousand or thousands of files... Thanks!
Below is the script:
function jobArrived( s : Switch, job : Job ) {
var debugLevel = s.getPropertyValue( "debugLevel" );
// create the file handler
var fileList = new File(job.getPath());
// open the file for reading
fileList.open(File.ReadOnly);
// read each line into an array
var lines = fileList.readLines();
var theSourcePath;
for(i = 0; i < lines.length; i++) {
sourcePath = lines[i];
// don't process blank lines
if (sourcePath == '') {
continue;
// create a file handle for the file to be moved
sourceFile = new File(sourcePath);
if (!File.exists(sourcePath)) {
s.log(3, sourcePath + " does not exist");
continue;
// get the name of the file (without the path information)
fileName = sourceFile.name;
// create a new job using the name of the file to copy
newJob = s.createNewJob(fileName);
jobPath = newJob.createPathWithName(fileName, true);
// copy the file to the new job.
s.copy( sourcePath, jobPath );
if(debugLevel == 1){
s.log(2, "Copy " + sourcePath + " to job");
// trim hierarchy segments
var jobPathArray = sourcePath.split("/");
jobPathArray.splice(0, s.getPropertyValue("Trim_Hierarchy"));
jobPathArray.shift();
jobPathArray.pop();
// set hierarchy information
newJob.setHierarchyPath(jobPathArray);
// send the file along to a single connection
newJob.sendToSingle( jobPath );
s.log(2, "Send to single: " + jobPath);
s.log(2, "Done processing");
// cleanup
job.sendToNull( job.getPath() );
fileList.close();
