Connect 2017 Ships!
Michael Reiher
Connect 2017 Ships!
Post by Michael Reiher »
I'm happy to announce that Connect 2017 is now available!
In this release, we focused on compatibility with Switch 2017 and Pitstop 2017, as well as providing improvements with basic job tickets, our update server, and many other little adjustments and tweaks.
In addition to the above, for Connect ALL and YOU customers, we include a new preset project we called "Check Job Essentials". This project was created for prepress operators, customer service reps, and designers to quickly check a PDF's essentials. This includes, trim page size, image resolution, number of pages, inks defined, and if fonts are embedded all based on your selections. In addition, it also provides print quality PDF creation from any application, controls over converting inks or RGB colors to process color, and adding bleeds to any document.
With this new project, you can even print directly from MS Publisher, or MS Word and create a print quality PDF with bleeds, and proper CMYK inks — even converting RGB blacks to pure 100%K.
It's a tool meant to be easy to use, and easy to understand so that even a CSR can quickly check an incoming PDF... but it's also powerful where it will help prepress operators catch more complex mistakes such as the use of transparency, or poorly defined inks.
To use it, you just have to select the project from the Preset Projects list and make the Connector.
We're very excited about Connect 2017 and hope you enjoy it too. Also, for those of you looking for new Plug-ins to support CC2018.... they will be released shortly. We expect to post those by the end of this month.
Check with your local Enfocus authorized reseller, or contact our sales department to check on your upgrade options.
Thanks and enjoy!
Michael
JimmyHartington
Re: Connect 2017 Ships!
Post by JimmyHartington »
Is Connect Send also updated?
Michael Reiher
Jimmy... yes. The entire Connect line got an upgrade to support Pitstop and Switch 2017.
JimmyHartington
Ok. I have yet to recieve my information about the upgrade. I have maintenance on it. Should I contact support?
Michael Reiher
You should contact your Enfocus Reseller who sold you Connect, or write sales@enfocus.com to see where your upgrade is. :-)
JimmyHartington
I will do that.
So this new version uses the new method to communicate with Switch?
And then I can also use the Switch Portal?
Michael Reiher
RE: "And then I can also use the Switch Portal?"
Yes... exactly. :-)
