XMP Metadata path found but Switch doesn't return the sample
Posted: Fri Nov 17, 2017 1:26 pm
Hi all,
I have some indesign scripts that adds XMP data to a document. It's later exported in PDF and enters the flow.
PDFs Custom XMP are like this :
The problem I have is that when I try to read those XMP metadata into Switch, I can totally nuild a path and reach the node. I can even see it's value in the browser. However the sample won't display any value. It's very weird.
What could explain such a behavior from your point of view ?
Best regards,
Loïc
<?xpacket begin="" id="W5M0MpCehiHzreSzNTczkc9d"?>
<x:xmpmeta xmlns:x="adobe:ns:meta/">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description xmlns:ozalto="https://ns.ozalto.fr/inks/1.0">
<ozalto:colorSequence>
<rdf:Seq>
<rdf:li rdf:parseType="Resource">
<ozalto:NbCol>4</ozalto:NbCol>
<ozalto:SeqCol>PANTONE 1935 C,PANTONE 531 C,PANTONE Black C,die cut</ozalto:SeqCol>
</rdf:li>
</rdf:Seq>
</ozalto:colorSequence>
</rdf:Description>
</rdf:RDF>
</x:xmpmeta>The problem I have is that when I try to read those XMP metadata into Switch, I can totally nuild a path and reach the node. I can even see it's value in the browser. However the sample won't display any value. It's very weird.
Best regards,
Loïc
