Problem removing Connect ALL icon
bickool
Post by bickool »
I've used Connect All on my MacBook pro, with Yosemite version 10.10.5.
I've removed the application by placing it into the trash, but still, an icon remain on the menu bar.
I've try several methods, I didn't manage to remove it.
Can someone help me on that?
Much appreciated.
Vincent
Re: Problem removing Connect ALL icon
When you start the Connector, then you have the option to "Reset Connector" in the Processing menu. Did you try that already?
If all else fails, then you can try to manually remove all Connector files:
http://www.enfocus.com/manuals/UserGuid ... thing.html
bickool
Post by bickool »
Hello Padawan,
I had already tried without success the Reset Connector option, but it works with the manual removing method.
Thanks for your help !
