Re: pdftk and cat command
Posted: Sat Feb 06, 2021 8:57 am
Deo gratias freddyp in quotes tips. has adiecit mores effugium
Thanks freddyp on the quotes tips. has added escape character
i've also added PDFtk to the windows environment variables
Still no luck though, exit code = 1 and PDFtk complain it can't find the file :
Now i need to figure out how to execute the *.bat file
Btw, dkelly i reckon PDFtk doesn't like the "'," the array added in between and i has revert back to building the command string.
//pdftk A=fronts.pdf B=back_x1500.pdf shuffle A B output print_job.pdf
var jobFolder = job.createPathWithName(job.getNameProper(), true);
var pdfFilename = jobFolder + "/" + job.getNameProper() + ".pdf";
var fronts = '\"C:\\SwitchTemplate\\PCFrontV01.pdf\"';
var backs = job.getPath();
var AA = "A="+fronts;
var BB = "B="+"\""+backs+"\"";
var CC = "\""+pdfFilename+"\"";
command = "pdftk"+" "+AA+" "+BB+" shuffle A B"+" output"+" "+CC;
var exitCode = Process.execute(command);
s.log(2, Process.stderr);
s.log(1, command);
s.log(1, exitCode);
When running the command at cmd prompt, it only works when output destination is changed to location outside of AppData eg: "c:\output3.pdf"Error: Unable to find file. Error: Failed to open PDF file: "C:\SwitchTemplate\PCFrontV01.pdf" Error: Unable to find file. Error: Failed to open PDF file: "C:/Users/ADMINI~1/AppData/Local/Temp/2/FixtureTest01/inFolder2/_00001_playingCardBack_v01-X56.pdf" Errors encountered. No output created. Done. Input errors, so no output created.
Thanks jan_suhrpdftk A="C:\SwitchTemplate\PCFrontV01.pdf" B="C:/Users/ADMINI~1/AppData/Local/Temp/2/FixtureTest01/inFolder2/_00001_playingCardBack_v01-X56.pdf" shuffle A B output "C:/Users/Administrator/AppData/Roaming/Enfocus/SwitchScripter/temp/1/ScriptElement/1/13/playingCardBack_v01-X56/playingCardBack_v01-X56.pdf"
