Selecting Spot Color by name "None" not possible?
yosimo
Post by yosimo »
There is an action called "Select Spot Color by Name", which works fine for all the usual Spot Colors.
But what about the Spot Color with the special name None ? I can not create an action that works with this special spot color name.
Is there a solution for this? I'm working with PitStop v13.2.
Re: Selecting Spot Color by name "None" not possible?
I have PitStop Pro 17, update 1. An Action List like this reports objects with Spot color None
Select Spot Color by Name, "None"
Log selection
Does this work for you? Are you doing something else?
