Portrait or Landscape?
w2pcrew
Post by w2pcrew »
We are building a Preflight Flow and want to set in the Preflight Profile that there is no difference wether the PDF is in Portrait or Landscape Format.
Would be great if there is someone who can help us :D
Re: Portrait or Landscape?
Not totally sure of you request but PitStop Profile Pages tab will let you check for different pages orientation in the doc and possibly fix the file so every pages share the same orientation.
Does that help ?
stefanghettler
Post by stefanghettler »
Hey w2pcrew,
how you doing?
I'm from America, but if you could send me your location, I could fly to your country and solve your problem.
Kind regards,
Stefan "Ghetto" Ghettler
Paul Lewis
Post by Paul Lewis »
Hello w2print,
I'm not really following the objective here.
Are you wanting to check all pages have the same orientation or, do you NOT want to fail preflight if a job has it's width and height dimensions around the wrong way compared to a job spec such as XML ?
We have solved a potentially similar problem here with regards to job dimensions around the wrong way.
Paul.
