Pickup / Retrieve PDF from URL [SOLVED]
NEOSA
Post by NEOSA »
Hi All @Forum,
I have an XML file (this file come from a Web platform), informations about the PDF (asset file) to download is inside :
<?xml version="1.0" ?>
<order_detail>
    <cpdf_url>http://www.drukzo.nl/upload/xyz.pdf</cpdf_url>
    <cpdf_md5>mymd5sum</cpdf_md5>
</order_detail>
Which setup do you use with Switch to pickup the PDF ?
Switch Server has Configuration Module + Scripting Module + MetaData Module.
Many thanks for clues/ideas ;-)
Regards.
Re: Pickup / Retrieve PDF from URL
The HTTP Request element will download the file in the URL.
NEOSA
Post by NEOSA »
THANKS Jan ;-)
It was so evident, I missed to check with the Tool :-)
A great thanks again.
Have a nice day.
