HP SmartStream Error Messages
Posted: Tue Aug 21, 2012 2:41 pm
by littly_kittly
I have created a Smart Stream job and have sent it to the printer to print it.
The job is sent as a JYLT fast template file.
When the printer prints it, he gets the following error message:
test3_20375_covers Number of columns in database does not match number of columns referenced in the job: Columns 152, Fields 599 OBJ 1 0
I have run a preflight on the job and it finds no errors.
I would appreciate some suggestions, as I am at a loss as to how to even to begin to troubleshoot this.
Thanks!
The printer being used to print them is:
Two Indigos. A 7000 and a 7500.
The DFE is running version 4.6.25 I-Fix 1
System manager version 2.1.74
Posted: Tue Aug 21, 2012 2:53 pm
by dkelly
Hello, that error message does not have anything to do with the PDF file format and won't be detected by a PDF preflight program. Rather, it is related to the database not having the same structure as what the file references, mostly probably related to variable data field(s).
Posted: Tue Aug 21, 2012 4:23 pm
by littly_kittly
Hi
Thank you so much for taking the time to help me. I really do appreciate it.
When I say "preflight", I mean the Preflight that is built into Smartstream.
How do I go about troubleshooting that?
In Smartstream, I click on "Verify database" and it gives the following message:
Some DB report rows contain more fields than the DB header. The rows are: 1-132
What does this mean?
Thank you for any help you can offer.
Posted: Fri Aug 24, 2012 5:36 pm
by littly_kittly
After lots of troubleshooting, I have found that the problem lies with the images.
Are there any special settings that have to be used when using images with a fast template smart stream file?
I have saved my images as an EPS.
