Flow to catch duplicate files
neecerp
Post by neecerp »
Has anyone set up a flow that would catch duplicate files coming through a folder in Switch?
I need it to catch a file with the same name no matter when it may show up. Whether within 1 minute or 5 days later.
We would like to then send a report via email, which is the easy part.
Any ideas? I was thinking maybe I could use Assemble job somehow, but I do not want to assemble anything.
Zoranj
Re: Flow to catch duplicate files
Post by Zoranj »
You could setup database to update with name of each file and check if it exist.
I second Zoranj. You need to store passed jobs either as a database call maybe writing down some file locally or whatever suits you.
neecerp
Post by neecerp »
What kind of database? I am talking about using Switch flows.
Can you suggest examples?
Zoranj
Post by Zoranj »
I have both of these in active use
You setup database in MSSql or some other database.
For this you need database configurator license.
When file passes, you check database if the file name exist, if not you take name of the file and write it to database.
If file exist in database, you do whatever the action you want.
Loic's example would be "cheap" database made out of folder with files.
When file passes, you you use Inject Lite to check if file with name exist, if not inject txt file into folder repository and name it with file name.
If file exist, do whatever action you want.
In this case I am using Inject lite instead of regular Inject since it will not fail when it does not find file.
I hope this helps
flussidicaio
Post by flussidicaio »
with the scripting module it would be easy.
without you can try with "inject job".
See the attached file
