Calculate media usage
Terkelsen
Post by Terkelsen »
I'm trying to calculate the total media usage for several PDF-files. I'm using the calculation feature to calculate the total area of a single PDF (with multiple pages). I do that this way:
[Switch.Calculation:Expression="([Stats.MediaBoxHeight:Type="Defined"]*0.035278)*([Stats.MediaBoxWidth:Type="Defined"]*0.035278)*[Stats.NumberOfPages]",Precision="2"]
This returns the result in square centimeters. I store the result in Private Data. Is there any way to calculate the sum of this number for all PDF's contained in a folder (apart from merging the files before doing the calculation).
ldewilde
Re: Calculate media usage
Post by ldewilde »
Hello Terkelsen,
There is a new Counter app that does the job:
https://www.enfocus.com/en/appstore/product/counter
Laurent De Wilde
Xerox BeLux
Terkelsen
Post by Terkelsen »
That's great Laurent!
However, there seems to be a problem for Switch to accept the value calculated for Surface counter. I've send you an e-mail on support@ezflow.xyz
ezFlow
Post by ezFlow »
Hi Erik,
The bug with the decimal values has been fixed.
The v2 of the app is available in the appstore, be sure to update!
