We are testing Connect You at a government site (eventually will install Connect All). Installing Connect You on the computer at this site requires logging in as the Admin user. However to use Connect You, they need to be the Standard User. Is it possible for Connect You to be installed in the Admin account but used in the standard User account. Note this is a government office and it will be a long process to get government IT Dept to grant app install rights to the standard User. Hence we need to be able to install in Admin but run in User. Is this possible?
Regards,
Ken
Install and Use on different accounts
Michael Reiher
Re: Install and Use on different accounts
Okay... I got clarification... you can install under Admin, but the user account needs to be granted permission to access the Application. Once that is done, it should work as expected.
Let us know if this is not the case.
Michael
Michael
