HP Smartstream error - "Registration code is invalid"
Posted: Tue Jul 10, 2018 2:43 pm
Hi all, I keep getting an error with Smartstream Designer when I submit csv variable data in a submit point. As soon as it hits the Smartstream configurator I get the following error. If I quit InDesign and submit the data file again, the job will process normally without error. Is anyone else getting the same? I'm using Switch 2018 with latest version of HP Smartstream Designer.
-<SmartStreamStatus>
<Status value="Failure"/>
-<StatusReportList>
<StatusReport value=" Registration code is invalid" page="" id="ERROR_CREATE_JOB" type="Error"/>
</StatusReportList>
</SmartStreamStatus>
