Intermittently i am getting the following error from the HTTP Request element
TCP/IP error occurred: Connection closed.
The HTTP request tool failed to connect to the server or the connection was interrupted
Whilst this is an error, the job does not go into the error folder but the HTTP Request element is paused. If i right click and retry the jobs they then go through.
Does anyone have a work around for this. I would to be able to set the retry to be automatic.
HTTP Request Error
r.zegwaard
Re: HTTP Request Error
In the preferences, you can set "Error handling > Retry failed external processes after" to e.g. 1 minute.
Thank you so much.
I´d be careful - some failed tasks might run forever…
Sebastian Nafroth
Sebastian Nafroth
