PitStop Server Watchdog has restarted...
Posted: Mon Oct 08, 2018 9:50 pm
I have the latest version of PitStop Server installed however for some reason, I receive the following error multiple times per day: "PitStop Server Watchdog has restarted PitStop Server Processor because of an unexpected problem."
I've checked the event viewer but I'm not seeing any events that correlate to the time and/or issue.
I've done quite a bit of searching and can't pinpoint anything in particular. Aside from calling support, has anyone else experienced this issue before? We're currently running everything with a local user on the computer in order to take advantage of some plugins in Switch. I'm not sure if this is causing the issue but I figured it was worth mentioning.
