HTML forms remember last value
ericnd01
Post by ericnd01 »
Is it possible to replicate the behavior of "Remember last value" in an HTML form? If so, how? I have a pretty extensive form created, but every time the connector is launched, the fields are empty. Is there a Javascript trick or something to be done on Switch or ConnectALL? Thanks!
ericnd01
Re: HTML forms remember last value
Post by ericnd01 »
I was able to accomplish this using Javascript and cookies. If anyone knows an easier, more direct way please let me know.
Is it possible to share your javascript? It could be useful for others having the same issue.
ericnd01
Post by ericnd01 »
I tried to cleanup the code to provide just the relevant information, so I can't guarantee this will work as provided. Basically, I run onload="checkCookie()" to check if any cookies are saved (getCookie) and populate the form fields if they exist. Any changes to a field automatically updates the cookies (setCookie). There's probably a more efficient way to do this, but it works for me so I'm chalking it up as a win.
<html xmlns:EnfocusConnectNS="http://www.enfocus.com/2013/EnfocusConnectMetadataPreset">
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
    <script type="text/javascript">
        function setCookie(cookie) {
            document.cookie = cookie.id + "=" + encodeURIComponent(cookie.value) + ";expires=Tue, 1 Jan 2030 00:00:00 UTC; path=/";
        function getCookie(cname) {
            var name = cname + "=";
            var decodedCookie = document.cookie;
            var ca = decodedCookie.split(';');
            for (var i = 0; i < ca.length; i++) {
                var c = decodeURIComponent(ca[i]);
                while (c.charAt(0) == ' ') {
                    c = c.substring(1);
                if (c.indexOf(name) == 0) {
                    return c.substring(name.length, c.length);
            return "";
        function checkCookie() {
            var elements = document.getElementById("enfocusForm").elements;
            for (var i = 0, element; element = elements[i++];) {
                var cookieValue = getCookie(element.id);
                if (cookieValue != "") {
                    document.getElementById(element.id).value = cookieValue;
        function getJobInfo(jobAttribute) {
            let urlParams = new URLSearchParams(window.location.search);
            return urlParams.get(jobAttribute);
    </script>
</head>
<body onload="checkCookie()">
    <form action="http://localhost" method="post" autocomplete="on" id="enfocusForm" novalidate="" name="EnfocusConnectMetadata" enctype="application/x-www-form-urlencoded">
        <div>
            <ul>
                <li id="cid_1" data-type="control_head">
                    <div>
                        <div>
                            <h1 id="header_1" data-component="header">
                                Connect Uploader
                            </h1>
                        </div>
                    </div>
                    <center><h4><script>document.write(getJobInfo("jobname"));</script></h4></center>
                </li>
                <li id="id_name">
                    <label id="label_name" for="name">Your name</label>
                    <div id="cid_name">
                        <input type="text" id="name" name="name" data-type="input-textbox" size="20" value="" data-component="textbox" onchange="setCookie(this)" />
                    </div>
                </li>
            </ul>
        </div>
    </form>
</body>
</html>
