Folder Structure Using Hiearchy
Posted: Tue Oct 09, 2012 8:18 pm
				Can a folder structure be setup at the beginning or the end of a flow using any of the Hierarchy flow elements WITHOUT them nesting? I want 1 root folder and 5 subfolders in it that are not nested? Do I need to write a script for this? I have a Set Hierarchy element that is using a variable condition to name the root folder in the Path Segment 1, which works. I set the Path Segment 2 to the name of the first folder, which works also. Then trouble.... all the other Path Segments 3-5 are all nested, which is what I don't want. I tried adding individual Set Hierarchy elements for each folder and that didn't work either.... still nesting. Any help would be much appreciated. Thank You!
