Shifting close to trim content to specific x
So client wants to shift contents too close from trim (inside) to a security distance of 3mm. Identifying those close items is no big deal. On the contrary, positioning them to the specific x coordinate is a challenge.
The position content script allows you to either set a fixed location (x,y) which is great for half part. I can set x but I don't want y to change and it won't be the same value obviously.
Second possibility is to use relative displacement. But then that would mean every sing object would be displaced with same value. So objects could be moved very far away if they are just very close of the security margin.
Has anyone tackled this kind of stuff before ?
Best regards,
Loic
