Exporting metadata
LasseThid
Exporting metadata
Post by LasseThid »
I have a flow to which I submit files thru a Submit point.
At the end of the flow I would like to export the metadata set Submit from the pdf in order to be able to import it in case I need to alter an imposition created by Phoenix, since that metadata is not present in the Phoenix job. Using Export metadata I can export the set, but how do I save it in order to be able to import it in another pdf and preferably keeping the same name, i.e. Submit, for the metadata.
LasseThid
Re: Exporting metadata
Post by LasseThid »
Even though it would be interesting to know if you can re-import a metadata set that you have exported, I found a much better way of dealing with the issue I have...
As Gabriel once told me.... Abuse Private Data... :lol:
Just use an XML-pickup
r.zegwaard
Post by r.zegwaard »
Using Pack / Unpack you can save / restore all metadata for a job.
Note that you can unpack a packed-job only once...
LasseThid
Post by LasseThid »
I did that Jan, but for some reason the exported metadata set wasn't formatted like an xml'file needs to be, so even though the XML pickup worked I was unable to see the metadata. On the other hand it was 10.30 pm when I did the test... :lol:
