JavaScript working with an array
cwswitch
Post by cwswitch »
I get this info
info = (job.getVariableAsString('[Job.NameProper:After="(",Before=")"]'));
It looks like this 10,5,10,20,10,10,20,10
I'm looking to put that info into an array and then access parts of the array
So far any effort to put it into an array or access parts of that result in 'Undefined'.
Can anyone please let me know how to put the info into an array and then access parts of that array?
(or another way if this is the wrong way)
EDIT I forgot to mention that I'm aiming to access the part of the array with another variable. So when I want to access part x of the array, then I'll be using a variable which equates to x.
Thanks!
r.zegwaard
Re: JavaScript working with an array
Post by r.zegwaard »
Hi
I guess this should do the trick ;)
infoString = job.getVariableAsString('[Job.NameProper:After="(",Before=")"]');
infoArray = infoString.split(",");
cwswitch
Post by cwswitch »
Thanks for the help!
Is it possible to echo variables from a script out to somewhere to see what a script is producing?
I think I was making the array OK, but trying to echo out an array (so undefined) and not echo out a position of the array. Silly me :roll:
Post by gabrielp »
cwswitch wrote: Wed Mar 13, 2019 10:22 pm Is it possible to echo variables from a script out to somewhere to see what a script is producing?
You could log a variable and read it there:
var myCoolVariable = [1,2,3,4,5]
job.log(1, "MyCoolVariable: " + myCoolVariable.toString() );
var myCoolIndex = 3
job.log(1, "Selected value for index " + myCoolIndex.toString() + ": " + myCoolVariable[myCoolIndex].toString() );
Which would probably log something like the following:
MyCoolVariable: 1,2,3,4,5
Selected value for index 3: 4
cwswitch
Post by cwswitch »
THIS makes my life much easier. - Thanks
rashirane579
Post by rashirane579 »
Excllent topic! Thanks for such an helpful thread. It was a helpful post for me as I had a same question.
kwoodVisions
Post by kwoodVisions »
Wouldn't the index of 3 then be 2 and not 3 since indexing starts at 0, not 1.
