Check if pages with trim box of size X*X exists
Posted: Wed Mar 20, 2019 1:35 pm
Can any body crack this for me. I'm obviously not familiar enough with action lists.
What I want to do is to have action list to give an error in case there isn't pages in document that has trim box larger than user defined value.
Example I have an document that has two pages in the beginning with trim box "430x297" and arter that all the other pages are "210x297".
So the action should be able to see that there are pages that are bigger that "210x297" and give it a pass.
And in case the document only has pages with trim box "210x297" the action would give an error.
Sound a bit up side down probably but I need for Fiery JobFlow workflow that uses Pitstop actions.
I started with:
Select all
Check page size
But when there is those larger pages there are also pages that are under the determined value and they trigger the error anyway.
I then tried to proceed with:
Select by page size
Check page size
But I just can't figure it out.
I started with:
Select all
Check page size
Select by page size
Check page size
