JavaScript to Save as idml file in Indesign
Flow666
Post by Flow666 »
I need to save some Indesign document to older versions (idml).
But i can't find any samples from javascript in combination with Switch on how to do this.
Can somebody point me to some sample files.
The manual from Switch isnt very helpfull.
Post by dkelly »
You could try something like:
var regex = /.indd/gi
var fileName = app.activeDocument.fullName.replace(regex, ".idml");
app.activeDocument.save(File(fileName), true);
Flow666
Post by Flow666 »
I am using the Indesign Configurator to process my jobs.
The settings i use are:
Open = Automatic
Command = None
Save = Use Script
Do i have to use the $code instead of app.activeDocument to get it working?
Or do i use the code in SwitchScripter?
I am getting errors that no documents are open.
Yes, you do and you have to fill out the $outfiles array so Switch knows what output files your script created. See the Switch help: Introduction - Advanced topics for designing flows -Javascript for applications.
Here is the code:
var tempDir = "/Users/fp/Desktop/";
var fileName = $doc.name.replace(".indd",".idml");
$doc.exportFile("InDesign Markup (IDML)",tempDir+fileName);
$outfiles = []
$outfiles.push(tempDir+fileName);
$doc.close;
Switch will automatically remove the temporary file, by the way.
Flow666
Post by Flow666 »
Thanks dkelly and freddyp. It works!!
I found that in my older script the documents where still open, but not visable.
With the $doc and $outfiles it works, thanks a lot.
TLagueux
Re: JavaScript to Save as idml file in Indesign
Post by TLagueux »
I was using this script but it does not work anymore since I installed the last update.
Any idea why?
Regards,
Thierry
Hi THierry,
By update you mean an update of InDesign? If so, which version are you running now?
Do you get an error in the messages?
Corporate films
Post by Corporate films »
Hey there
I am using this InDesign for saving my JavaScript but not getting good results.
Please suggest what to do.
For reference http://www.corporatefilmsmumbai.com/gallery.html
