Creating low res pdfs
LasseThid
Post by LasseThid »
I have a flow that at one stage of the flow creates a low res pdf. When we had Switch running on a Mac this worked perfectly, however since we moved to Windows the destiller will fail with this error in messages: "Error while distilling file 'C:/Users/Admin/AppData/Roaming/Enfocus/Switch Server/backing/Indigo Submit/automanaged/Destill/_00MZ4_P167241_STIHL_NORRASKOG_ERBJUDANDE_A4 (002)_Korrektur.ps'; check Distiller log output for more details". There is no file places in the Logs folder going from the Acrobat Distiller.
If I drag the postscript file to Acrobat Distiller it will distill just fine.
Any Ideas what might cause this problem?
